OpenVPN configuration using two-way TLS authentication
The disadvantage of the secret key authentication method is that its theft from one of the participating VPN hosts leads to the necessity of changing this key from all participants. This raises the question of how to transfer the new key through an insecure Internet channel safely. Therefore, if needed to connect several clients to the server, one should choose TLS authentication.
In this case, each party has its own private key, which is not transferred anywhere. Only the client's public key certificate signed by the CA is transmitted. Such certificates are issued for a certain period of time by specialized organizations for money. But for organizing VPN inside your company, if there are no special requirements for security, you can use your own certifying centre.
Now let's consider an example of creating keys and certificates in Windows to connect two clients: Keenetic-2 and Keenetic-3 to the Keenetic-1 server.
To create all necessary keys and certificates, we need a set of EasyRSA scripts from the OpenVPN package version 2.4.6-I602 for Windows, which also uses the openssl utility included in it.
To install EasyRSA, mark the component 'EasyRSA 2 Certificate Management Scripts' when installing OpenVPN:
In OpenVPN 2.5.x versions, to install the EasyRSA scripts, press the 'Customize' button on the first installer screen and scroll to the bottom of the component list.
Open the Windows command line as an administrator.
  1. Go to C:\Program Files\OpenVPN\easy-rsa and run:
    init-config.bat
    As a result, we will get a vars.bat file that configures the environment for generating your keys and certificates.
    Open this file in Windows Notepad and specify a folder to store them; by default, it's 'keys':
    set KEY_DIR=keys
    as well as the default values of your certificate owner's fields, for example:
    set KEY_COUNTRY=GB
    set KEY_PROVINCE=YourProvince
    set KEY_CITY=YourCity
    set KEY_ORG=YourOrganisation
    set KEY_EMAIL=mail@example.com
    set KEY_CN=CommonName
    set KEY_NAME=KeyName
    set KEY_OU=OrganisationUnit
    Save the changed file.
  2. Create new index.txt and serial auxiliary files by executing (once) in the Windows command line:
    vars
    clean-all
  3. Create a private key and certificate for your certificate authority by doing the following:
    vars
    build-ca
    The generated ca.key and ca.cert files of your certification authority will appear in the C:\Program Files\OpenVPN\easy-rsa\keys folder.
  4. Create a Diffy-Helman file to protect your traffic from decryption. The TLS server will use it. In some cases, the procedure may take some time ( for example, when the key size is 4096 bits, it takes tens of minutes), but it has to be done only once:
    vars
    build-dh
    The file dh2048.pem (or dh4096.pem when using a 4096-bit key size) will appear in the C:\Program Files\OpenVPN\easyrsa\keys folder.
  5. Create a private key and certificate for the OpenVPN TLS server (Keenetic-1) by executing:
    vars
    build-key-server Keenetic-1
    When the script asks for Common Name (CN), enter the server name, such as Keenetic-1. In the end, double confirm (y) that you are signing the certificate.
  6. Create the private key, PEM request and certificate for the first OpenVPN TLS client (Keenetic-2) by executing:
    vars
    build-key Keenetic-2
    When the script asks for Common Name (CN), enter the name of the first client — Keenetic-2. Confirm twice (y) that you are signing the certificate.
  7. Repeat the previous step for the second client (Keenetic-3):
    vars
    build-key Keenetic-3
    When the script will ask for Common Name (CN), enter the name of the second client — Keenetic-3. Confirm twice (y) that you sign the certificate.
    Similarly, you can create keys, queries, and certificates for any number of clients.
  8. Create an HMAC key for additional protection against DoS attacks and flooding by executing:
    vars
    openvpn.exe --genkey --secret keys\ta.key
    At this point, all the necessary files are created:
    The following files are required for use in OpenVPN server and clients configs:
    • ca.crt — certificate of the certification centre
    • dh2048.pem (or dh4096.pem) — Diffy-Helman file
    • Keenetic-1.crt — OpenVPN server certificate (Keenetic-1)
    • Keenetic-1.key — OpenVPN server private key (Keenetic-1)
    • Keenetic-2.crt — certificate of the 1st OpenVPN client (Keenetic-2)
    • Keenetic-2.key — private key of the 1st OpenVPN client (Keenetic-2)
    • Keenetic-3.crt — certificate of the 2nd OpenVPN client (Keenetic-3)
    • Keenetic-3.key — private key of the 2nd OpenVPN client (Keenetic-3)
    • ta.key — HMAC key for additional protection against DoS-attacks and flooding
    The only thing left to do is to add their contents to the server and client configuration text files.
  9. To create an OpenVPN server configuration file, use the example server.ovpn located in the C:\Program Files\OpenVPN\sample-config\. You will need to insert the keys and certificates into it as follows:
    1. Replace the line:
      ca ca.crt
      with the section:
      <ca>
      -----BEGIN CERTIFICATE-----
        <--Insert the body of the certificate of the certification centre from the file ca.crt here
      -----END CERTIFICATE-----
      </ca>
    2. Replace:
      cert server.crt
      with the section:
      <cert>
        <--Insert the body of the OpenVPN server certificate from the Keenetic-1.crt file here
      </cert>
    3. Replace the line:
      key server.key
      with the section:
      <key>
      -----BEGIN PRIVATE KEY-----
        <--Insert the body of the OpenVPN server private key from the Keenetic-1.key file here
      -----END PRIVATE KEY-----
      </key>
    4. Replace the line:
      dh dh2048.pem
      with the section:
      <dh>
      -----BEGIN DH PARAMETERS-----
        <--Insert the contents of the file Diffie-Helman dh4096.pem here
      -----END DH PARAMETERS-----
      </dh>
    5. Uncomment the line:
      topology subnet
    6. Replace the line:
       server 10.8.0.0 255.255.255.0
      with the line:
       server 10.1.0.0 255.255.255.0
    7. Comment out the line:
      ;ifconfig-pool-persist ipp.txt
    8. Replace the line:
      tls-auth ta.key 0
      with the section:
      <tls-auth>
      -----BEGIN OpenVPN Static key V1-----
         <--Сюда вставьте содержимое файла ta.key
      -----END OpenVPN Static key V1-----
      </tls-auth>
      and add the line:
      key-direction 0
    9. Comment out the line:
      ;status openvpn-status.log
  10. To create the configuration file for the first OpenVPN client, use the example of client.ovpn located in the C:\Program Files\OpenVPN\sample-config\ . You will need to insert the keys and certificates into it as follows:
    1. In the line:
      remote my-server-1 1194
      replace my-server-1 with the domain name or public IP address of your OpenVPN server (Keenetic-1).
    2. Replace the line:
      ca ca.crt
      with the section:
      <ca>
        <--Insert the body of the certificate of the certification authority from the file ca.crt here
      </ca>
      cert client.crt
      with the section:
      <cert>
        <--Insert the body of the certificate of the first OpenVPN client from the file Keenetic-2.crt
      </cert>
      key client.key
      with the section:
      <key>
        <--Insert the body of the private key of the first OpenVPN client from the Keenetic-2.key file here
      </key>
    5. Replace the line:
      tls-auth ta.key 1
      with the section:
      <tls-auth>
        <--Insert the contents of the ta.key file here
      </tls-auth>
      and add the line:
      key-direction 1
    6. Add a line with the route to the server's local network:
      route 192.168.1.0 255.255.255.0
      or:
      route 0.0.0.0 0.0.0.0
      if all traffic needs to be routed into the tunnel.
  11. Repeat the same actions for the second client by taking the data from Keenetic-3.crt and Keenetic-3.key files, respectively.
    Examples of such configuration files for three Keenetic clients are attached at the end of the article:
    You can use them by replacing the KEENETIC-1.mykeenetic.co.uk client name in the clients' files with the domain name or public IP address of your Keenetic-1 server and certificates and keys to the files generated by you.
    Now all you need to do is download them to Keenetic routers in the same way as in 1.5, 1.6 and perform the actions described in 1.7, 1.8 of this manual.
    This is the end of the setup. Check that the tunnels are set up.
    To do this, run ping the server's tunnel address from the client's side:
    ping 10.1.0.1
    and the server's address on its home network:
    ping 192.168.1.1
In the second part of the example, for simplicity, we performed all the operations in one folder, although for security reasons, it is recommended to place the certification authority on a separate computer, isolated from the Internet, and store the secret key only on it; and carry the certificate on removable media. Similarly, the private keys of the server and OpenVPN clients should only be placed on the respective sides of the tunnel. Only certificates can be exchanged.
We recommend that you read the following information:
