Keenetic routers can use multiple WAN connections simultaneously in balancing mode. Any WAN interface — wired, modem, DSL, WISP, PPPoE, etc. — can participate in balancing.
Balancing will be most effective for multithreaded traffic (point-to-multipoint or one-to-many connections), such as torrent traffic, P2P or other protocols that open multiple connections that do not require saving the source address. In this case, the connections will be distributed over different links.
Balancing will not work correctly for point-to-point or one-to-one connections because most hosts will drop packets from the same session if they come from different IP addresses. For example, an HTTPS-enabled website or web service that opens multiple sessions might not work because if some sessions are routed to different ISPs, it will trigger security and errors for the HTTPS protocol.
Below, as an example, we will enable balancing mode for BitTorrent protocol (it is easier to demonstrate the operation of this mode for multithreaded traffic).
You need to set up a separate Internet connection policy. On the 'Connection priorities' page, on the 'Internet connection policies' tab, you need to click '+ Add policy' and specify the name of the new policy, for example,
torrent-multipath
. Here policy is a set of rules and routing policies applied to hosts' traffic when they access the Internet.Importante
Balancing mode does not work in the default policy, only in additional policies.
In our example, the Main and Backup connections are intended to provide Internet access and maximize bandwidth while downloading a file for the BitTorrent protocol.
In the right column 'Connection', you need to check only them and save the settings.
Here, on the 'Connection priorities' page, click on the 'Policy bindings' tab. The 'Show all objects' option lets you display all devices registered in the local segments and the local network segments configured on the router.
By holding down the
Ctrl
key on your keyboard with the mouse, you can select multiple devices at once. In our example, you need to move only one object (hostMYHOST
) to the previously addedtorrent-multipath
policy.Prioritizing the Main and Backup connections.
The load ratio is determined by the priority value of the
ip global
interfaces within the connection policy. The priority of the Backup connection must be lower by one than the priority of the Main connection. In our example, priorities65533
and65532
are used.To make the balancing work, you will need to set the
ip global
value for Main and Backup via the router's command-line interface (CLI). In our example, theGigabitEthernet0/Vlan4
interface named Main and theISP
named Backup:(config)>
interface GigabitEthernet0/Vlan4
Core::Configurator: Done. (config-if)>ip global 65533
Network::Interface::Ip: "GigabitEthernet0/Vlan4": global priority is 65533. (config-if)>exit
Core::Configurator: Done. (config)>system configuration save
Core::ConfigurationSaver: Saving configuration.GigabitEthernet0/Vlan4
interface for1 Gbit/s
orFastEthernet0/Vlan14
interface for100 Mbit/s
.(config)>
interface ISP
Core::Configurator: Done. (config-if)>ip global 65532
Network::Interface::Ip: "ISP": global priority is 65532. (config-if)>exit
Core::ConfigurationSaver: Saving configuration.Enable balancing mode for the
torrent-multipath
policy:(config)>
ip policy Policy5
Network::PolicyTable: Policy "Policy5" exists. (config-policy)>multipath
Network::PolicyTable: "Policy5": enable multipath. (config-policy)>exit
Core::ConfigurationSaver: Saving configuration.In our example, the
torrent-multipath
alias corresponds to the policy's name of thePolicy5
:(config)>
show ip policy
policy, name = Policy5, description = torrent-multipath: mark: ffffd05 table: 47Here, in the command-line interface, check the routing table.
The numbering of the Internet connection policies (
ip policy PolicyX
) starts at42
ip policy Policy5
is numbered47
:(config)>
show ip route table 47
================================================================================ Destination Gateway Interface Metric ================================================================================ 0.0.0.0/0 192.168.209.1 GigabitEthernet0/Vlan4 253 0.0.0.0/0 193.0.174.1 ISP 253 10.1.30.0/24 0.0.0.0 Guest 0 151.236.14.119/32 192.168.209.1 GigabitEthernet0/Vlan4 0 172.16.82.0/24 0.0.0.0 Wireguard2 0 192.168.3.0/24 0.0.0.0 Bridge2 0 192.168.22.0/24 0.0.0.0 Home 0 192.168.209.0/24 0.0.0.0 GigabitEthernet0/Vlan4 0 193.0.174.0/24 0.0.0.0 ISP 0 193.0.175.0/25 193.0.174.10 ISP 0 193.0.175.22/32 193.0.174.1 ISP 0 193.187.91.26/32 192.168.209.1 GigabitEthernet0/Vlan4 0 194.32.146.82/32 192.168.209.1 GigabitEthernet0/Vlan4 0After enabling balancing mode, a default route is added within the Additional policy for the interfaces added to this policy. In other words, if two ISP interfaces are in the table, it means that multipath works.
Check the Download speed on connected interfaces in the web interface on the Dashboard.
Channel rate of Main and Backup connections up to
100 Mbit/s
=12.5 Mbytes/s
:The download speed is summed from the two connections, so we get up to
22.4 Mbytes/s
=179.2 Mbit/s
.To
disable
balancing mode, you will need to run the following commands via the router's CLI:(config)>
ip policy Policy5
Network::PolicyTable: Policy "Policy5" exists. (config-policy)>no multipath
If you have 100 Mbit/s
and 200 Mbit/s
Internet channels, you need to set the first Internet connection to ip global
value 10000
and the second Internet connection to ip global
value 20000
. Then the balancing will work in the ratio of 1 : 2
, and the total speed will increase up to 300 Mbit/s
The balancing mode also works for the Download Station built into KeeneticOS. You can assign a connection policy for the BitTorrent client with the command torrent policy <connection_policy>
