In this section:
- Updating KeeneticOS
- Where can I see the KeeneticOS release notes history?
- Resetting the router's settings and the administrator password
- KeeneticOS recovery
- Internal service traffic
- FAQ: component installation and updating KeeneticOS
- zRAM virtual swap file and HWNAT traffic accelerator
- Saving your router's self-test system file to iPhone/iPad
- SSH remote access to the Keenetic command line
- Terminal program for Windows
- How do I restore access to the web interface?
- How to regain access to the web interface
- How does a firewall work?
- Configuring firewall rules from the command-line interface
- Copying, moving and deleting multiple firewall rules
- Disabling all LEDs on schedule
- Changing the IP address lease time
- Using the zRam swap file
- Brute force protection function for the router password
- Enabling Telnet and TFTP client in Windows
- Accessing the web interface of a Keenetic operating in one of the additional modes
- Rebooting a router on schedule
- Restoring Keenetic router settings from a backup configuration file
- How to check the network adapter settings in Windows
- How to change the network adapter settings in Windows to automatic mode
- Network accelerator engine
- Restoring KeeneticOS (for advanced users)
- Disabling STP support on a router switch port
- Loop detection on switch ports
- Setting up Ping Check to ping a LAN host
- How to add a USB modem that is not on the list of supported?
- KeenDNS frequently asked questions
- When should port forwarding and firewall rules be used?
