Which Keenetic models are suitable for the Mesh Wi-Fi System?
Mesh Wi-Fi System works with all current Keenetic models (with a KeeneticOS version 3.1 or higher). Any model can act as the controller (Main Router) of your Keenetic Mesh Wi-Fi System or an extender, except for the Keenetic Buddy models, which only act as an extender.
Always choose a more advanced router like a gigabit model or the one with USB ports as your Main Router. If your Internet tariff is higher than 100 Mbit/s, the main router should be a gigabit model like Skipper, Hero, Titan, Peak, Hero 4G+, Hopper or Hero DSL. As Wi-Fi range extenders to it, you can choose Speedster, Sprinter or Explorer models equipped with an operating mode selector on the case for quick adding to Wi-Fi System without preconfiguring. It makes sense to use Speedster and Sprinter as an extender for a wired connection to the main gigabit router and Explorer for a Mesh Wi-Fi connection. Alternatively, compact Wi-Fi range extenders, Buddy, which plug directly into an electrical socket, can be used to extend the coverage of your Wi-Fi System.
Extenders with gigabit ports are very desirable to connect with a wire. It is not even necessary to stick to the 'star' topology, you can use a daisy chain connection.
If your Internet tariff is up to 100 Mbit/s and you do not plan to change it for a higher speed, you can choose Carrier as the Main Router and add one or more Explorer or Buddy 5 models as extenders.
Connecting over the air to get a Mesh network is most effective in dual-band models of the same or close Wi-Fi class and especially 100 megabit models because a 5 GHz backhaul connection is likely to be even faster than over cable. For example, ideal kits start with Carrier while adding the necessary number of Explorers or Buddy 5.
If you rely entirely on Mesh Wi-Fi rather than wire, it is advisable to limit the maximum number of Keenetic devices on the network to five, including the Main Router. In most cases, models with the same port and Wi-Fi network speeds will suffice. But when it is not the gigabit Ethernet and Wi-Fi speed that is important, but the budget and the coverage area, the low-cost dual-band model Explorer and Buddy 5, or even single-band Starter and Buddy 4 will do. Two entry-level routers can easily turn into the Mesh Wi-Fi System with seamless roaming, WPA3 security, network segmentation, and centralized management.
For a Wi-Fi System, with the latest Wi-Fi 6 (802.11ax) standard, use the AX1800/3000/3200 class Wi-Fi models. For example, Titan (KN-1811), Hero (KN-1012), Hero 4G+ (KN-2311), Hopper (KN-3811) or Hopper SE (KN-3812) models will work as the Main Router, and Sprinter (KN-3711), Sprinter SE (KN-3712), Buddy 6 or Voyager Pro models as an extender.
